camshaft replacement
  1. S
    Multiple Misfire 2009 Ram 1500 5.7 - Need Help
    Hi guys, new to posts and ram 5.7 truck in General. But basically my issue is the multiple misfire code I am getting, and it does not show me which cylinder is actually misfiring. I had got the truck for a fair price due to misfire on cylinder #5 and did all the basic tests and ended up needing...
  2. Manual Gen 4 Ram
    Accidentally misaligned cam and crank... Please help
    2014 Ram 1500 Sport 5.7L After replacing the camshaft and lifters my truck a few months ago I was going into limp mode, but only when the engine was cold. I checked the computer and it showed codes P0016, P000B and the timing changing between -13 and -16° off. The engine ran fine other than the...
  3. Kasey
    Camshaft swap
    Hey guys, I just finished a camshaft replacement, got it all back together cranked the engine and cant get it to idle. If I press the gas it will stay running but if it drops below say 1500 to 1000 RPM it dies. Any advice on where to look? It's a 5.7 hemi 2012
