Camshaft swap
Kasey
Fort worth
Hey guys, I just finished a camshaft replacement, got it all back together cranked the engine and cant get it to idle. If I press the gas it will stay running but if it drops below say 1500 to 1000 RPM it dies. Any advice on where to look? It's a 5.7 hemi 2012
jws123
nj
sounds like timing may be off Did you do it the right way and pull the oil pump so you can set it 100% with the marks or did you do it the lazy way like most of us and wing it with the pump still on. I found out the hard way was worth it to pull the pump. Also make sure your alternator is hooked back up. Re check all vacuum lines and all other plugs ect..
Burla
2010 Hemi Reg Cab 4x4
run code, "maybe" camshalf position sensor as well, it shuts down to protect the engine. Other then that it might be fuel or air, kinda of doubt "spark".
cam install thread.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Everyone else that replace cam with this issue either bent a pushrod or timing was off.
Kasey
Kasey
Fort worth
But if it was a bent push rod it would only misfire on the cylinder the bent rod is on. I'm getting a random misfire with leads me to believe it could be the timing.
Kasey
Kasey
Fort worth
Kasey
Kasey
Fort worth
I did it the right way and took off the oil pump when I put the new chain on all the marks was in place
Burla
I hope so, but we get a lot of bent rods often, thus random misfire happens.
Tach_tech
5.7L HEMI
Either timing is out or a bent pushrod are the most likely issues.
A bent push rod can cause other cylinders to misfire not just the one cylinder. The valve not opening or not opening properly can disrupt air flow. Same thing can happen with a broken spring. I’ve seen one broken valve spring on a hemi cause it to not start at all, and if it would start it would have a dead miss on half the cylinders.
Start with the easiest things, check all your coil/injector connectors. Make sure there’s no vacuum leak.
Do you have access to a scan tool that can read data?
Kasey
Kasey
Fort worth
I have a buddy that's got one. But I discovered before work I have my passenger side head gasket is leaking good chance that's what is giving me the no idle and random misfire after work I am going to change out the gasket and try it again
Tach_tech
5.7L HEMI
Did you make sure the head gaskets were on the correct side?
Kasey
Kasey
Fort worth
I believe so I just think the gaskets I got were not so good it came in a full gasket kit I picked up on Amazon for 130$ I'm going with the feltpro on the passenger side tomorrow
Tach_tech
5.7L HEMI
The gaskets have a TOP and L and R stamped on them. See what happens after you get the gasket fixed.
jws123
nj
lol Yea make sure u have the right gasket installed left and right are dif they almost look identical to.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Head gaskets are an easy seal with modern fully-machined components.
Burla
It should be P or D because you never know if they mean left from drivers seat or facing the engine.
It's usually always from the seat,left or right is still left or right even on a right hand drive vehicle.
Kasey
Kasey
Fort worth
The gaskets I got had no stamps or marking lol
