differential drop
  1. 9
    Front end rattle over bumps
    Hi there, I have a 2017 ram 1500 with a 2” level kit. I have had a rattle for awhile now and figured it was my cv axles and differential shafts because of the play. I had those replaced and the rattle is still there. I have new struts, upper control arms, and new sway bar links. Anyone have an...
  2. T
    Rear Diff blew up.
    Last week the rear diff blew up on the truck and im thinking ill just replace the whole rear end and go with a 3.92 instead of 3.55 is this just an easy pull out put another back in or is there more id have to do? I have a commuter car so if im using my truck, its for truck things, im not to...
  3. MaxSteel2013
    Dirt King Fabrication LTS Kit Install Prep - HELP
    I am ordering the front and rear long travel kits, but prior to installation I need to remove the 4" "MOPAR" suspension lift the dealer installed. My dilemma: The install of the diff drop bracket required frame modifications to the lower control arm mounts. I have a former employee willing to...
