differential gears
  1. Rob McClure
    rear diff fluid question
    hey yall, my 1500 has the 3.21 rear gears ( i know ,lol ) without limited slip , I talked to ram to verify that it didn't have limited slip and they confirmed and the y sent me the build sheet which is pretty cool , my question is , I have Amsoil 75w/140 fluid am I good to run that in the diff ?
  2. ArDavid318
    Gear wear pattern
    Hey fellas. Got a couple pics of the gear tooth wear in my 9.25. I was curious what you guys thought. Last winter I did my first ring and pinion. I installed nitro 4.10 gears along with all new bearings. As much as I thought I did everything correctly I’m assuming I set them up wrong. I gathered...
  3. M
    Gear ratio swap for highway
    Hello everyone. I have a 2003 2500 Cummins with power upgrades with a nv5600 6-speed, AAM 11.5 373 gears. I use it to pull a 5th wheel RV. The 1st gear I use for maybe 3sec and 6th gear revs a bit high cruising down the highway, feels like I could use another gear. I think the best way to...
  4. D
    Chrysler 9.25 differential grease mesh pattern
    I got a new ring and pinion for Chrysler 9.25, I know how to set backlash by adjusting the two threaded inserts on the sides and setting backlash to .006-.010” of play, the other measurement is pinion depth which is determined by shims, I keep playing with the system and setting it up and...
  5. ArDavid318
    Gear ratio problems
    Hey guys Doing a bit of figuring out here and I hope I’m in the right place. I have a 98 ram with slightly modified 318. Behind that 318 I have a nv4500 I swapped in last year. It originally had the nv3500. Anyway I would like to be able to use 5th gear a little better. My problem is that it...
  6. 2010_Laramie
    Ideal 2500 Laramie Gear Ratio for Towing
    Hey everyone, Though I'm new to this forum I've owned my truck for about a year now and I think it's time I get a new truck since I need one that has better towing capability. I have my eye on a 2500 Laramie that the seller is willing to trade for my 1500 Laramie (they are the same year and...
