rear diff fluid question
Rob McClure
Portland Oregon
5.7 hemi v8
hey yall,
my 1500 has the 3.21 rear gears ( i know ,lol ) without limited slip , I talked to ram to verify that it didn't have limited slip and they confirmed and the y sent me the build sheet which is pretty cool , my question is , I have Amsoil 75w/140 fluid am I good to run that in the diff ?
hemihustlin
Lower Southwest Quebec
if you already have that in stock go for it
i think they call for 75 90 in the 3.21 and 75 140 in the 392s so you will be good for max tow rating of your gears haha
dont forget the transfer case if you have one!
LOL ! yes I know the front t-case uses different fluid View attachment 585758
Little tidbit for you,it's "not" a front transfer case,it's a front diff.The transfer case is behind the transmission and is bolted to the back of the transmission in a Ram 1500. You'd be farther ahead learning to call it the front diff,as that's what it is,saves a $h!tload of misunderstanding when you ask questions. You didn't call the rear diff a transfer case,so don't call the front diff a transfer case either ;)
Smartass answer or not,i could care less,but lets keep it correct and simple to save on mistaken answers Rob
hemihustlin
in reality gear oil is alot like motor oil, you chose viscosity according to intended/actual usage.
the guy thats towing all the time, extreme hot/cold or at the drag strip et cetra has different requirements than the average grocery getter in an "optimal" climate
even more important is regular maintenance. many people never change their gear oil so may the strongest pinion bearing win!!!
