Davido1001
I got a new ring and pinion for Chrysler 9.25, I know how to set backlash by adjusting the two threaded inserts on the sides and setting backlash to .006-.010” of play, the other measurement is pinion depth which is determined by shims, I keep playing with the system and setting it up and running it through mesh paint and adding or subtracting small shim sizes, this has gotten me close, here is the mesh pattern attached to this post, what do I need to do??? Is this mesh pattern due to incorrect pinion depth? And If so do I need to add or subtract shim thickness?? And if it’s backlash, what do you suspect I am doing wrong with setting that?? Also if it is pinion depth how much should I adjust it by? I’ve been adjusting it by .005 inches, should I go buy smaller shims?? Thank you for your help!! (First pic is slanted side of tooth and second photo is flat side of tooth)
