dual zone
  1. R
    Single to Dual zone ATC with donor vehicle
    I have a 2014 Ram 2500 SLT 5.7 with a RA5 radio. I have added Remote Start and Backup Camera. I have access to a donor vehicle, 2014 Ram 1500 Longhorn gas engine. The 8.4 (unknown whether it was Nav) radio has been taken but I have access to the dual zone ATC control panel, 7” EVIC, dual zone...
  2. D
    Installed New OEM Actuator, get error code B11CB-92 Performance or Operation Incorrect?
    I have replaced the two actuators right behind the temperature control panel (OEM), one after market actuator right behind the glove box, I know there are two more behind the dash. one is right behind the firewall (you have to disconnect and depressurize your a/c) and one you can just access...
  3. B
    Heater/Fan question 2010 Ram 15 Hemi
    My First post here so ill try to have this makes sense. I just put in a new heater core and some actuators. this fixed my dual zone no heat on the drivers side issue. Full heat everywhere and its back to normal new now. the question is ill start the truck, the heater fan starts as normal...
  4. g00fy
    Dual Zone Climate Control Issues, Factory Software Glitch?
    Is anyone else having a really strange behavior with their Dual Zone climate controls? I retrofitted a 12" UAX system into my tradesman which has a single zone blower, but I was experiencing very strange behavior. When it was cool out, say below 65*, I would set the temperature to 70, and from...
