engine codes
  1. aaronfuzion
    Need help with 2004 5.7 intermittent starting and other electrical issues
    Hey guys, thank you in advance for your input and experience. I'm not big on fixing my own vehicles (I prefer building new things out of wood over maintaining things made of metal!). I know that's not cool around here, but my various mechanics are at a loss on this vehicle. I've got a 2004 RAM...
  2. LongTom
    2011 Ram 2500 5.7L Poor Performance
    Hello everyone, I recently purchased a 2011 Ram 2500 5.7L 4x4 Crewcab Longbox with I believe 3:73's a few weeks ago. Truck has an engine code (P0420) for catalyst efficiency below threshold on bank 1. Truck feels a little underpowered for 390 HP and If i am absaloutley driving like a grandma at...
  3. LongTom
  4. Jerm317
    PO481 code/check engine light comes on every time it rains and it turns off when everything is dry.
    I have a 2012 Bighorn 4door 5.7 Hemi 4x4 with about 105,000 miles on her , so keep having a check engine light / PO481 code coming on when every it rains and says on for a day or two sometimes less sometimes more and then turn off , PO481 code is for a relay for cooling fan #2 I have replaced...
  5. F
    New wire harness destroyed my engine.
    To start I have a 2013 Ram 1500 (3.6) I was getting a bad misfire on cylinders 3rd & 5th. I went ahead and replaced the ignition coil for all 6 cylinders as well as the spark plugs. The misfires continued and it was determined that the problem was the wiring harness. I took it to a Dodge...
  6. R
    1990 dodge ram D250 question
    I'm thinking about buying a 1990 dodge ram D250 and the engine maintenance light came one for him and he took the bulb out because it was starting to get annoying, and before I buy It I want to check for engine codes with the ignition ON-OFF-ON-OFF-ON trick but I'm worried about what light that...
Reticle918
