engine noise
  1. A
    2013 Dodge C/V noise
    Does anyone have any thoughts as to what this noise could be coming from? Dodge C/V with 222,000 miles on it. It is in park. https://youtu.be/H3l5IHQurCw?si=lCwnNx7eq7lfOgIx
  2. Units
    Still getting used to my diesel
    When I start my truck up, I usually let it run for a minute before I take off, when I drop it in D and go it sounds like I can hear the fan or something like it kick on for about 10-20 seconds while accelerating and then it quiets back down. It usually only does it when I first start it up and...
  3. StruggleBus
    Fan Clutch Engaging With AC on
    So, I've got a 2022 Ram 2500 Limited with a 6.7 in it and about 1200 miles. Since day 1 it Seems like when the A/C in on the fan clutch will be on a lot. Dealer says everything is operating fine but the other day a coworker got his 2022 2500 (same truck as me but red) and his fan doesn't come...
  4. S
    2020 RAM 2500 6.4L - Loud tick even after lifter replacement at 19K miles
    Hello RAM Forum, First off this is my first RAM purchase so I'm new to the RAM 6.4L hemi engine and all its glory and not so glorious issues. At around 7K miles my engine developed a loud ticking noise (see video). I took it to the dealer and they said it was "normal" ( I have this in writing...
  5. S
    Engine noise on cold start
    Can anyone help with what this noise may be? It happens on cold start and usually lasts 10-15 minutes. 1-2 hours after driving there aren't any noises. I took it in to the dealer the first time and they replaced the idler pulley & tensioner belt. Got the truck back and started making this noise...
