esc light
  1. M
    Airbag light, seatbelt light, ESC light, no cruise
    I’ll try to be brief. So I replaced the heater core in my truck. This requires removing the entire dash. I also unbolted the seats and moved them back to give myself more working space. Once put back together heat works great. Truck drives normal. BUT now I have lights for my airbags...
  2. S
    New Clock spring BUT NOW guess what
    New clock spring was installed OEM in my 2014 1500 4x4 . Local shop who has the RAM software did it. Closest dealership is 4 hours away. Anyway. The original issue was my son spun the wheel when I had the steering colum disconnected. Threw air bag warning and ECS along with the brakes engaging...
  3. oldmitch
    Hydraulic ram-assist steering
    I just finished installing my steering assist kit. Pretty straight forward. Although I will point out that if you're not paying attention *points at myself* it's REAL easy to cover the world in power steering fluid, when you're bleeding the system. Also, during the bleeding process, you need to...
