fuel gauge
  1. W
    Fuel gauge stuck on full after pump replacement
    Hey everyone I know this has been talked about a couple of times but I cannot find any posts with the exact same scenario. My fuel pump went out a week ago. I opted for the bosch replacement. I didn't run into any particular issues during the install and went with the lifting the bed strategy...
  2. B
    Fuel Sensor Fail... should I fix it?
    I have a 2014 Ram 1500 with just under 60k miles on it. A couple weeks ago the check engine light came on, followed by a Fuel Sensor Fail warning. Took it into the shop today and they quoted me $1,200 to replace the fuel pump. I've read other threads on here where guys just fill up their tank...
  3. B
    2011 Ram 2500 fuel gauge not working after fuel pump replaced
    Hi everyone, First of all, I have just about no clue regarding trucks or vehicles in general. I am here to try to help my husband find out info about his 2500. About a month ago, truck suddenly wouldn’t start. Had it towed to a shop. Shop said the fuel pump needed to be replaced, which they...
  4. A
    Fuel Level Sender fail after filter change
    So is it a really strange coincidence or could it be a cause? Changed fuel filters as well as oil and air. Upon restart I get a fuel sensor error and gauge doesn't work. During this time I also put the spare back in its mount. Was off due to tail ight not getting power and I had to run a...
  5. D
    02 fuel pump install
    My car was beginning to have a delay when going to start it up so I finally went and changed the pump. Initially I put the pump in bolted the bed back down and took the near empty truck to the gas station to fill up. I filled up and the gauge remained where it was. Day 2 I tilt the bed to the...
  6. El Huapo
    Fuel gauge reading backwards??????????
    I'm guessing that I hurt a wire somewhere under the dash when I lifted the dashboard and dropped the steering column to check the heater core. I know that I had about 1/8 of a tank of gas when I disconnected the battery and did the heater core check. I got it all back together and started the...
