head gasket
  1. J
    intermittent heat issue
    i have a 2011 ram 3500, studded and new head gasket. truck runs perfect except every so often it starts to run hot. new thermostat ( 3rd one i have put in, never checked them just replaced them hoping for the best ) new water pump, new engine fan and radiator cap. i can drive the truck for...
  2. lucasgunzz
    Blown head gasket?
    Noticed my 07 5.7 was leaking a little coolant the other day. Well I forgot about it and went and started it and it was putting out plenty white smoke. Is it a blown head gasket? How much Trouble is it to change that on your own? Thanks in advance
  3. D
    2005 Dodge Ram 1500 4.7 Head gasket or cracked head
    I have a 2005 Dodge Ram 1500 4.7 liter engine non-flex. I know in some capacity I am getting coolant into my cylinders. I'm not sure if my head gasket is bad or could it be a cracked head. I bought this truck used back in January so I don't know a lot of history on the truck, unfortunately. I...
  4. R
    Oil Leak By Head 2018 Ram Powerwagon
    Hi everyone I am new to the forum and unfortunately my first post will be in regards to a problem with my 2018 power wagon with 22k miles on it. My previous vehicles were a Raptor and then a Hellcat now Power Wagon which I do love but I am not happy with at the moment. I do have an extensive...
  5. D
    2010 Ram 5.7l heads
    Good evening i did head gaskets on my ram Yesterday due to leaking in to the cylinders truck ran fine though. But i was down about a liter of a/f a week and after pressure testing the system the white smoke out the tail pipe was a indicator.I had the heads sent out to the machine shop and they...
  6. Erianc
    Overheating/Oil Problem
    I have a problem with my 04 5.7. Just the other day, I was on my way to school in the morning and had the “Check Gauges” symbol pop up. Truck was overheating so I pulled over and the gauge went back to normal temp in less than a minute. I kept driving and the gauge would stay at 3/4 of the way...
