Dan Leveque
- Jun 1, 2019
- 10
- 0
- Location
- Manitoba, Canada
- 2010
- 5.7l vin t
Good evening i did head gaskets on my ram Yesterday due to leaking in to the cylinders truck ran fine though. But i was down about a liter of a/f a week and after pressure testing the system the white smoke out the tail pipe was a indicator.I had the heads sent out to the machine shop and they did valves and seats, pressure test. I got the heads back installed them and when i tried to start the truck i had a hard time starting it and when it finally did start it was missing on the back four cylinders.Using my scanner i could watch cylinders 5,6,7 and 8 dead miss.I am not sure what is going on i removed the valve covers and all pushrods are in place and ok there is no vacuum leaks.The only code in the system is p0300 random misfire but it does not run long.unless i bring the rpms up then cyl 5 stops missing but 6,7 and 8 continue to miss.I am out of ideas on what it could be other then putting the wrong head on the wrong side.But i do not know if that is possible.When i run the casting number of the head it is the number for the right head.
Any ideas would be greatly appreciated
