Hi so im having an issue where the climate control system, specifically the air flow knob just blinks, And stops working/ giving heat. Odd enough it works sometimes perfectly and gives heat. So I took it to a mechanic and he said it can maybe be the HVAC module or the climate control panel. Does...
Got my 2013 Ram 1500 4.7l having HVAC issues. It’s starting to get cold here in Texas and have already had some weather get to 30 degrees recently. Main issue I’m facing with HVAC is that when I put heater all the way hot, with engine at operating temp, passenger side is hot but driver side is...
I have a 2014 ram 1500 Sport with dual zone climate. Last winter I was having a problem with the heat changing gradually over to cool whenever I would drive for a half hour or more and I'd have to bump the temp up to get any heat. Next time I started the truck the heat worked fine unless I'd...
I have a 2015 2500 diesel with factory 8.4 unconnected. 2 years ago the heat would not turn on. It was locked out in both the screen and buttons. Took to dealer they replace the climate module. Last week same thing happened climate won’t turn on from the controls no heat no defrost no heated...
