help with
  1. L
    4.7 exhaust manifold
    Hello everyone I recently ran into a problem yup the 4.7 exhaust manifold leak. So I was tould both exhaust manifold needs to be change. So I have been searching the internet and I can’t find a store or web site that sells the manifold for the 4.7 v8. If anyone has any suggestions please let me...
  2. E
    Can't find it HELP!!!
    hi all I am looking for a rear driver side shock absorber mounting bracket for a 2005 ram 1500 the one that welds on too the chassis not the axle I only can find the front ones and don't know what universal one I could use Thank you .
  3. 3_Turner
    Help Needed - Part Name/Number Request
    Vehicle: 2008 Dodge Ram 3500 Megacab The circled part was attached to the column gear selector upon replacing and I broke the tab off of it. It looks to be a push lock of some sort but I have yet to find an actual name or part number for it. Currently, I only see this part on ebay bundled in...
  4. C
    Front differential
    I have a 2003 Dodge Ram 1500 4x4 and my front axles have a lot of play moving but it’s the stub shaft bearings and seal that went out, and I was wondering what bearings and seal to order and how do I go about changing them
  5. G
    Alternator Bearing Sizes?
    Hey all! My water pump went and took out the bearing on my alternator at the sasme time... So figured insted of just buying a new alternator I'd try replacing the bearings and maybe the brushes while im in there. Problem is I cant find an answer on what sizes to order. Lots of info for 3rd...
  6. J
    Installing new Dipstick tube on 2005 Dodge 2500
    Anyone have any incite on how to install new Oil Dipstick on the 5.7 Hemi. The old one broke and now it would appear that to install new one i would have to raise the motor off the mounts as the tube runs between the mounts and the block. Any help would be greatly appreciated.
Austinv
