Can't find it HELP!!!
ErickDCE
pa
5.7 V8
hi all I am looking for a rear driver side shock absorber mounting bracket for a 2005 ram 1500 the one that welds on too the chassis not the axle I only can find the front ones and don't know what universal one I could use
Thank you .
lharrell79
If you're referring to the bracket that's welded to the frame, I don't think you can buy them. They're part of the frame assembly. What happened to your old bracket? Did it rust out?
Any fabricator/welder should be able to make a new bracket and weld it in place. However, you would probably have to remove the bed to do the job right.
E
ErickDCE
pa
5.7 V8
Yes it did rust off smh, well thank you for your reply .
garjowan
mass
Hahaa, exact same thing with me, as well as my tailgate hinges...
Luckily, my broke off at the weld and stayed on the shock...
Just waiting for the time to lift the bed and weld it back on.
Any of the frame side universal should be able to be made to work, if you can weld, it just mount into the crossmemeber under the bed... you should be able to tell where the old one was.
Good luck!
No members online now.
Austinv
