hvac box
  1. ZCarramrod1
    2016 1500 hvac (Bighorn)
    lost cold A/C determined it to be the evaporator tried to replace the refrigerant (yf-1234) first myself and it didnt work found dye-color refrigerant leaking from the A/C-condenser at the front. Thought: "great now I don't need these actuators, evap and heater core or these aluminum blend...
  2. L
    Luke warm driver side, hot passenger side
    Got my 2013 Ram 1500 4.7l having HVAC issues. It’s starting to get cold here in Texas and have already had some weather get to 30 degrees recently. Main issue I’m facing with HVAC is that when I put heater all the way hot, with engine at operating temp, passenger side is hot but driver side is...
  3. D
    Question on Removal of HVAC 2013 Ram 1500...
    I have the Dash Moved out of the way... I am trying to get to the Blend Door Actuator on the backside of the HVAC box. but... it appears go get to that I need to remove this bolt: Which would then... I believe detach the line going to the AC. I think one is a pressure line the other carries...
  4. D
    Diagnosing problems with the HVAC box
    I am new to this forum please let me know if I'm posting this in the wrong place or if there is a better thread. I've been having a problem with my hvac only blowing down at the feet, sometimes it works normally but most of the time it doesn't. And recently I'm having the same problem with...
