knocking sound
  1. S
    2019 Ram suspension noise
    Got a 2019 Ram BTS 4x4 99k miles. Eibach shocks all around and 2 inch eibach lift springs up front. For about 9 months I've had this knocking noise up front. I think from the driver side. It happens when I'm braking and accelerating off a stop. It sounds like a cv play knock, or like the shock...
  2. T
    Brand new A/C clutch rattling when disengaged and engaged?
    Hi all. I've been reading through the forums for a while now, but this is my first time posting. 2015 Ram Laramie Limited 3.0L V6 Ecodiesel, 4x4, 107k miles Some back story first: Had oil cooler swapped out 2 weeks ago after finding the coolant bottle full of oil when I went to change the oil...
  3. okmitch77
    Knocking noise from under right side of dash
    Long shot, but I have a knocking noise that is coming from under the dash or maybe the firewall area on the right side. I have raised the truck and shook and yanked on all suspension parts. Its not the wheel bearing either. So went on reddit and somebody asked me if it only happens when the...
  4. Toasamoa1010
    Knocking sound at high RPMs (v6)
    I have a "17 RAM 1500, issue is there is a slight knocking sound when I accelerate. The engine doesn't as this seems to be the common issue when I do a search but when it's warmed up and I've been driving it for about 20mins, I notice is that when stepping on it, I hear a knocking sound as it...
  5. Larry Waters
    Strange clunking sound in the front end
    Strange clunking sound in the front and I have a sound it lightlyReverberates through the steering wheel. I notice it’s more prevalent obviously a bumpy road it almost sounds like a loose shock tower bolt. I took it to a non-ram shop they replace the tire rod ends wheel bearings steering bar...
