moes performance
  1. 2
    87mm Throttle Body require Tuning?
    I just bought a 87mm ported throttle body for my 21 Ram 1500 5.7 Hemi Etorque and a shop says it needs a new PCM or tuning but on Moe’s website it says no tuning required. Which is it?
  2. S
    Limited Slip Differential "Rear Master Install Kit"
    Hello everyone! I have been looking at buying the LSD from Moe's Performance, for 120 dollars you can get the "Rear Master Install Kit" but there is no description on what comes in that kit. Has anyone purchased this kit with the LSD? if so, what all comes with the install kit? Thank you in advance
  3. hydrobluesport
    Edge Pulsar Track results
    Anyone using the Edge pulsar with an upgraded throttle body like moes 87 mm or fastman, vararam intake and an upgraded muffler like the Carven or other brand? Anyone run a combo like this at the track and with what results? Edit: How about anyone running these type of mods with a canned...
  4. texan279
    Shout out to Moe's Performance!
    I wanted to give a shout out to Matt at Moe's Performance. I left work early to stop by and pick up an oil catch can. I didn't even realize his business is literally 3 blocks from my mother in laws. So I get there and we start talking. I end up leaving with the catch can, Vararam intake, and 180...
  5. Matt Perry
    Headers with Y- Pipe or do custom True Duals with an X- Pipe?
    So i recently purchased my old 2014 express 6 speed back after finding it online. When i originally had it I wanted to do a True Dual x pipe setup running to 5" tips in the rear. Would to true dual do anything besides sound? Or would it also add a bit of power/torque? Just trying to explore...
giantturkysub
