oil pressure gauge
  1. R
    Oil pressure reads 101 engine off
    Hey, I have a 2018 Ram 2500 6.4 Hemi. I replaced the oil pressure sensor because it read 101 PSI when the key was on but not started. Still reads 101, so I disconnected the sensor all together and checked the digital number. Still reads 101. Seems like a short somewhere. I jiggled wires but it...
  2. C
    Digital oil pressure reading at 100PSI but L and H oil pressure gauge reading normal. Check Engine Light on
    I have a 2016 Ram 1500 3.6. The check engine light came on and the oil pressure is reading at a consistent 100 PSI when idling and when driving. My L and H gauge is reading normal and appears to be functioning properly. Is this simply the oil pressure sensor needing to be replaced? I hear it’s a...
  3. Z
    Check Gauges light going on & off
    Hi, Checking to see if anyone has had a similar issue as I am having. I have an '05 with the 4.7. The "Check Gauges" light goes on and off many times while driving, and while the light comes on, the oil pressure gauge drops, but most of the time by the time the gauge gets all the way down, the...
  4. RAM4715
    Engine Oil Pressure
    I could use some help trying to ascertain what a min, normal range and max oil pressure might be. I'm not relying on the idiot gauge in the dash. I have a banks 0-100 psi sending unit mounted on the top of the filter housing. I was getting 0.2 psi at idle and 112 psi at 2000 psi. No doubt that...
  5. T
    Random Oil Pressure Readings & Hard/Long Start (Even after a engine rebuild)
    Vehicle: 2005 Dodge Ram 1500 - 5.7 liter hemi - 230k miles To keep things short, about 3 months ago, my truck experienced multiple problems in one day including, stalling, knocking, misfires, low oil pressure readings (oil pressure resets after restarting car). About a 2 weeks into working on...
  6. clanceman427
    how to diagnose inoperable oil pressure gage
    Hello, 1995 Dodge Ram 2500HD SLT with the 5.9l Magnum gasoline engine and automatic trans. The truck has the gage package so it has tachometer, oil pressure gage, temerature gage, etc. My oil pressure gage does not work at all. The temperature gage does. How can I begin to diagnose the oil...
  7. Tim Denning
    Need Oil Pressure Gauge Education
    My 1986 D150 has an oil pressure gauge that has been bypassed and replaced by an oil fed mechanical unit. I would like to remove the aftermarket item and return to the original gauge in the dash. I've bench checked the gauge and it is working so I'm assuming that either the wiring or the...
KAKA
