oil pressure sending unit
  1. WanderingOrphan
    Cannot Remove Oil Pressure Switch
    2004 RAM 1500 4.7 and I have a leaking oil pressure switch that I cannot remove as for some reason the socket(s) will not fit it. 1 1/16" deep socket fits the new one like a glove but the one in the truck is either rounded out enough that the socket just spins or it is smaller (which I doubt so...
  2. Tim Denning
    Need Oil Pressure Gauge Education
    My 1986 D150 has an oil pressure gauge that has been bypassed and replaced by an oil fed mechanical unit. I would like to remove the aftermarket item and return to the original gauge in the dash. I've bench checked the gauge and it is working so I'm assuming that either the wiring or the...
