oil pressure sensor
  1. R
    Oil pressure reads 101 engine off
    Hey, I have a 2018 Ram 2500 6.4 Hemi. I replaced the oil pressure sensor because it read 101 PSI when the key was on but not started. Still reads 101, so I disconnected the sensor all together and checked the digital number. Still reads 101. Seems like a short somewhere. I jiggled wires but it...
  2. BerserkingGator
    2016 5.7 Oil Pressure Sensor Help (Solved)
    Hello, I need some help regarding swapping out my oil pressure sensor on my ‘16 5.7 hemi. So I’ve watched many videos BUT my wiring clip seems to be missing the red tab required to release the sensor. Am I an idiot and my truck just has a different type on it? I never changed it in the past...
  3. M
    2015 5.7 L Hemi oil pressure issue
    Hello, my check engine light came on and I started getting low oil pressure so pulled the codes reference photos. Started with an oil change and oil pressure sensor replacement. While I was doing that I found metal shavings I finished the oil change and kept driving it after clearing the codes...
  4. C
    Digital oil pressure reading at 100PSI but L and H oil pressure gauge reading normal. Check Engine Light on
    I have a 2016 Ram 1500 3.6. The check engine light came on and the oil pressure is reading at a consistent 100 PSI when idling and when driving. My L and H gauge is reading normal and appears to be functioning properly. Is this simply the oil pressure sensor needing to be replaced? I hear it’s a...
  5. WanderingOrphan
    Cannot Remove Oil Pressure Switch
    2004 RAM 1500 4.7 and I have a leaking oil pressure switch that I cannot remove as for some reason the socket(s) will not fit it. 1 1/16" deep socket fits the new one like a glove but the one in the truck is either rounded out enough that the socket just spins or it is smaller (which I doubt so...
  6. D
    oil problems- Code: p0521/p0522
    I have an 07 5.7L Hemi, i first had code p0521 and I changed oil pressure switch and got an oil change, during the oil change they said my oil looks burnt and its only been 2k miles since my previous oil change. then i disconnected battery to reset computer and drove it around for a while now...
  7. D
    Chasing ghosts....
    2007 1500 5.7 hemi 163k - 30 miles into highway drive today I suddenly lost power and oil pressure according to dash - check gages light came on. Checked all fluids and FULL. No sign of leak or dump of fluids. On side of highway, replaced battery (bad cell) and had alternator tested (passed...
  8. R
    Oil pressure sensor
    I’ve got a 2002 Ram 1500 3.7l v6 and I discovered a pretty bad oil leak under the truck. Was coming from the oil pressure sensor where the plastic goes to the metal nut. I changed it, all ok. 3 days later the same has happened so put it down to a faulty part so replaced it again. The same has...
jimn
