parking brake
  1. T
    Parking Brake
    Looking for some direction to hopefully save me some time before I pull everything apart. 2005 RAM 1500 SLT 2WD Parking brake falls to the floor without any resistance. It even falls when driving if you hit a bump. I will be looking at the parking brake drum and pads regardless since the...
  2. chendrixson2
    Parking Brake Hanger Issue
    Hello, I have a 2015 Ram 1500 5.7 L and I noticed today that the parking brake hanger is rubbing against the driver side parking brake line. Is there a way I can fix this issue and do I need to get a new line for that side. Pictures are included. thank you in advance.
  3. chendrixson2
    Hello, I have a 2015 Ram 1500 5.7 L and I noticed today that the parking brake hanger is rubbing against the driver side parking brake line. I heard a rubbing sound with the windows down while going over bumps. Got under the truck that this what I found. Is there a way I can fix this issue and...
  4. MarineBSP
    Parking Brakes - DIY links and tips
    My 2018 RAM 1500 has about 90K miles and five Minnesota winters. I recently did a full brake job on all four corners . . . in the process I realized I needed new Parking Brakes (PB’s) and their hardware too. For those of you who may replace your PB’s (and rear brakes), this is my “Road Map to...
  5. P
    Rear brake assembly fix bolts re-installation
    Greeting! My 2012 Ram rear left packing brake lost everything, the base stand got twist, bought a new replacement: Question: the 4 bolts is really difficult to push back to the frame support, is there some special trick to do, or only use a big hammer? the bolts are like following images, there...
  6. Sheapdog
    What's this ?
    Need help identifying this hanging from my truck. Never noticed it before and seems awfully loose. Looks like I can tighten it. Seems odd that it would loosen up out of the blue.
  7. P
    Parking/Emergency Brake Issue
    Last night I was parked on my driveway and after putting the parking brake on, I went to go leave and pulled the lever. The pedal came back a little bit but the light was still on. After some investigation, I found that I had to pull the lever and also pull the pedal back further so that it...
  8. G
    2008 Ram Dash Light warnings flashing with no codes
    I have a 2008 Ram 1500 5.7 Big Horn edition. My TPM, check engine, abs, parking brake, check gauges, and tire pressure warning lights all come on at the same time and the speedometer and the tack drop down to zero. Square boxes also appear around all of the gear indicators above the mileage...
  9. af2018
    1500 rolls down hill with brake on?
    I might be missing something here, but my drive way is on a slight decline towards the road. Yesterday i backed the 2018 truck up the driveway, didn't put on the parking brake, put it in 'park'... and it rolled slowly down the driveway! now... in my experience, the regular brakes should be...
  10. D
    Rear Right Parking Brake Cable length on a quad cab 3500..?
    Hi Ram Forumers, I need to replace the rear right parking brake cable on my 2003 quad cab 3500. But Rock Auto lists multiple ones of differing length. My wheelbase is 140.5", but they list the standard cab as 140.5" and the crew cab as 160.5". No mention of quad cab. My approximate length...
  11. C
    Parking Brake Lever Stuck... Up?
    Hey all, This is a new one for me... I have never even heard of this happening to others. I got in my truck this morning to move it around my driveway, and the parking brake lever is stuck in the "Up" position. I use my parking brake every day, as to not apply unwanted extra strain on the...
  12. HenryMorgan
    Ram 3500 parking brake cable pulls loose at splice connection?
    My parking brake cables break loose at the splice connection under the truck when I apply the parking brake. As soon as I tighten the cables enough to for the E-brake to work and stop the truck, the cable usually pops out of the splice connection. I have squeezed the splices with vice grips to...
  13. A
    Parking Brake Issues / Improvements?
    My MY2015 1500 has a sagging parking brake cable and a warning light that will randomly come on (even with brake physically disengaged). Story below, but TL;DR - is there any sort of improved solution we can put on the trucks to avoid this in future? I'm not really down for replacing my parking...
