power door locks
  1. kdikert
    Driver side door power lock will not work
    Hi, The automatic locks will not work on my driver side doors. The passenger side doors work well, both from the key fob and the door lock button. The problem was intermittent at first, so that the issue happened only when it was rainy. I lived in sunny California at that time, so it happened...
  2. S
    Where is the Driver side Door Lock Relay?
    Trying to find the Drivers door lock relay. Found a diagram that says it is "On the PCB". Near as i can tell a PCB is Printed Circuit Board.
  3. W
    Power Door Locks
    I have a 2020 Ram 1500 Classic Tradesmen and I want to add power door locks. Using the key is fine when it’s just me but it’s quite the hassle trying to get the kids in. Any suggestions/ideas? I’m not the most mechanical guy so I’m hoping for something not to difficult. Thanks.
  4. D
    Door Lock Problem
    Hi, I have a 98 Ram and I have tried to look it up, but I can’t seem to find a thread with a similar problem. If I missed it, please redirect me. So my 98 has automatic door locks on it but they do not work. I have to use my key or push them manually. When I use the switch, both doors have a...
  5. NoFlyZone
    Problem: '06 RAM 2500 Remote Keyless Entry Disengaged
    '06 RAM 2500 5.9L Laramie, where the power door locks with keyless entry all stop functioning, and the chime sounds when the engine is turned off once the door is opened. I reset the power door locks so they once again work by following manual instructions by turning key to on/off 4 times, then...
