radio replacement
  1. Socalramfan
    Let’s see what you have….. non-OEM radio
    As many of you may know, Im in the final stages of completing a Laramie dash swap. I did not elect to go with the factory radio from the 2017 the dash came out of as it would have entailed also pulling the entire factory wiring harness. My plan was to simply use the OEM radio from my 2011 as...
  2. I
    Radio for 4th gen 1500
    Hey everybody, I'm looking for a new radio for my ram. Do you have any you recommend? I have a single din with a double din front. Just the stock radio. Looking for touchscreen with Bluetooth and preferably plug and play if possible. It's a 2013 1500. Thanks in advance!
  3. R
    Replaced Radio but still doesn't work
    My radio random got bars on the screen and the audio stopped working. I pressed screen off and it would never come back on. Every now and then it light up with the black screen for a second but nothing more than that and if I didn't drive the truck for a couple days the battery would die. I've...
  4. G
    2012 OEM Steering wheel control and backup camera conversion to aftermarket head unit
    I have a 2012 1500 Laramie with the uconnect touchscreen radio. I’m looking to replace the radio with an aftermarket one with apple car play but I would like to keep my oem backup camera and steering wheel controls but I can’t find one straight forward solution on how to do it or what install...
  5. B
    2019 classic 8.4 radio in gen 4
    I am looking at a 2019 ram 1500 classic 8.4in radio to swap into my 2018 ram 2500. It appears to be the exact same dash as the gen 4. Does anyone know if these 2019 classic's use the RA4 or the newer UAS models? Thanks
  6. J
    New 2018 1500 owner...question about replacing radio
    Hi all. I'm a new 2018 Ram 1500 owner. I want to replace that crappy 5 in. screen radio with something like a Kenwood dual-din touch screen headend. Just about every video I've watched says that the bottom section of the metal single-din bracket needs to be hacked out to make room for a...
  7. TomRF
    2020 Ram 1500 Laramie with crap 12” U-connect
    I’ve seen other threads with people who’ve had issues with the 12” U-connect screen. As of now, I have 17k on my truck. I’ve taken it to the dealership 14 times starting at 1250mi all the way through 14.5k mi. They swapped the radio out twice and replaced the original radio with two refurbished...
  8. D
    Mestro device for 2007 2500 w/ 5.9 cummins
    Hi folks.. I am looking to replace the radio of my 2007 2500 with a new radio/streaming (no siruis required)/ maestro type device that will not only do the radio/phone/USB music/bluetooth stuff, but also display the needed gauges (tranny temp, ext temp. boost) that are missing from the...
