Rear air suspension sensor data inverted!
LF:90mm RF:68 LR:-47 RR:-41
Fender height= Fronts:39” Rears:37”
Currently the truck is stuck in off-road 1, initially the trucks code weren’t showing sensor errors it was showing error:U0422 and would time to time allow you to set the ride height.
I...
This started out as an intermittent issue. I'm getting a message and a ding every time I accelerate through 6-8 mph. The message advises that I should service the front park sensors. The system then disables the front sensors (light in the button comes on). When parked, the sensors work as they...
