shift points
  1. 0
    4.56 Gears Early Shifts
    I recently installed 4.56 Gears on my 04 Ram 1500 Hemi. Driving around town in part throttle truck feels sluggish, shifts too early and bogs down on the hills. My SuperChips Flashpaq F5 Tuner doesn’t have gear size parameter exposed to adjust shift points. Holley customer support says they don’t...
  2. L
    Swapping the 2005 Hemi PCM into a 2004 Hemi
    Hello everybody, hope you all are doing well. Listen... I know this topic has been discussed, I've read every single thread on multiple forums of this topic. But none of them had a definitive how-to with an end result. There are a lot of threads on swapping an '05 PCM into and '03 Ram but...
  3. A
    Transmission issue
    Hello everyone new to the forum. My brother and I installed a used transmission(80,000 miles) in my father in laws 2009 1500 with a 5.7 hemi. Changed the filter and fluid on the used transmission before install. It drives good and shifts through all the gears good except from 3rd to 4th it has a...
  4. Elijah
    Q to those who purchased new lifted trucks with 35's and 3.21, question about AT shifting to 8th
    Over these past years dealerships have been selling lifted trucks. Based on the window stickers I've seen they have come with either 3.21 or the 3.92 gearing. I have a question Have you noticed when on the highway it not seeming to shift to 8th a lot? It is so odd. I drive the same way to...
  5. NCRaineman
    5.7 Hemi safe rev limiter / shift points
    Running a BullyDog tuner on my '12 with the 5.7L Hemi, which has the options to alter the rev limiter and WOT shift points for 1-2 and 2-3. I've done some reading on various sites and am curious as to what a safe rev limiter would be and where to set the WOT shift points at. Right now I've got...
Carbary
