steering wheel control module
  1. J
    U1008 steering wheel controls, heated/cooling seats, exhaust break, not working.
    So my 2011 3500 longhorn, steering wheel controls (expect for speed control), heated/cooling seats, exhaust break, 115v outlet all don’t work. I checked all the fuses and they all seem fine, none are blown. Swapped the relays around, no change, grounds all look good. Wondering if it could be...
  2. X
    Can I drive lowered safely?
    I had the dreaded service air suspension alert. Took it to the dealership and it was diagnosed as the steering wheel control module and the part is back ordered till aug 2nd. The truck is lowered all the way and the compressor is not working or disabled. I replaced the fuses. But the truck is...
  3. TurboTruck
    Horn & Audio Controls Not Working, NOT Clock Spring issue! PLEASE HELP!
    So about a year ago, I noticed the audio controls on my steering wheel stopped working, as well as the horn. Cruise control, dome lights, etc all work properly. No codes thrown, no airbag light has come on. After extensive research, it HAD to be the clock spring! Right? Well I just replaced it...
  4. rjwin
    Steering wheel airbag control module question
    My airbag light is on. The dealer said that there is a module that controls the steering wheel airbag and that it needs to be replaced. $700.00. I thought there was only one airbag control module. Does anyone know about a separate module for the steering wheel airbag alone?
  5. R
    2011 RAM 1500 Clock Spring
    I'm a bit frustrated at the moment. I recently ordered a Clock Spring for my 2011 RAM 1500 Laramie Longhorn because my air bag light came on a few weeks ago and my steering wheel controls quit working, to include the horn and cruise control. When I received the part I noticed that the part...
