suspension lift
  1. B
    4” Zone lift, looking at different front struts
    Currently have the zone 4” lift on my 2012 ram 1500. I’ve veered away from the spacers in the kit a few years back and installed rough country’s 4” lifted N3 struts. They rode well for the first year or so. I’m looking into replacing them now as the ride is a little rough. I no longer have the...
  2. R
    Need help choosing suspension components and wheels/tires
    I apologize in advance for the noob questions.. I have a stock 2020 Ram 1500 Classic but I want the front to be level with the rear. At first, I thought about getting a leveling kit, but the more I read about those, the more I want to stay away from them. I think I will get some Bilstein 5100...
  3. Gage H
    Lifted Ram swaying at high speeds or heavy load
    Hey guys, I have a 2015 Ram 1500 with a Maxtrac suspension. I’ve experienced some pretty bad sway, mostly at high speeds or when the bed has a heavy load. I’ve tightened these bolts on the right with a breaker bar and it temporarily fixes the issue, until it loosens up again. What exactly is...
  4. RetiredBCDanny
    2017 Ram Lift and leveling
    4 inch RC suspension lift installed however the front end was 2 inches lower, installed RC 2 inch leveling springs now the front end is 1 inch higher vs the back, how's does this happen? The ride seems ok for the most part, how can I raise the back 1 inch for leveled truck of am I sol?
  5. ISellRams22
    Done
    Debate over. Last week I installed the icon stage 2 at 3” in front and 1.5” in rear with UCA’s and new digressive coils. All Icon, loving it!
  6. J
    Need Advice for Suspension Lift on 2018 Ram 2500 with stock air susp
    I have a 2018 Ram 2500 Limited 4x4 Mega Cab with factory air suspension in the rear. I would like to keep the factory air suspension. I want just enough lift to fit 35 12.50s and have zero rubbing and no trimming. Also maybe improve on the factory air suspension. I'm aware most likely I will...
  7. Alec Broschart
    Worn out springs causing rear to sit lower than front? Help
    Hey guys, recently had my 2012 ram 1500 lifted. There's been a couple of issues, the mechanic couldn't use the shocks that rough country sent me because they would simply fall out when the truck was lifted for some reason, he kept mine in their which didn't seem to cause any problems. However...
  8. Siveace
    Will It Fit? Tires & Rims
    i own a 1998 Dodge Ram !500 5.9L V8 Magnum RWD. i am going to be installing a skyjack 2" poly value spacer lift with nitro shocks. than a 3" body lift (specific kit not picked out yet). Currently i have the stock 16" rims and stock tire size on the truck. After I do the suspension and body...
  9. J
    FOX. ICON, or KINGS 4 inch suspension lift
    Which of these lifts are best for my 2018 ram 1500 big horn 4x4 for a 4 inch suspension lift I want to run 35’s but I’m trying to figure which lift is better as a daily driver, light off roading and medium at most. best in the long run, as well will put all of the angles in the best spots?
  10. Z
    Front suspension parts list w100
    I'm in the mechanical process of fixing up my 1988 w100. So far I've replaced the ujoints at the axles (and about to do the pinion side front/rear drive shaft ujoints), front brake lines/rotors/calipers, new drums/shoes, valve cover gaskets, plugs, battery, front/rear diff fluid, and gas tank...
  11. F
    Suspension between generations
    Out of curiosity, how much did the front suspension change on the 2wd, between the generations?
  12. A
    RC Vertex Coilovers
    Has anybody heard when RC is gonna be offering their vertex coilover upgrade on the Ram 1500??
glsander
