Siveace
5.9L V8 Magnum
i own a 1998 Dodge Ram !500 5.9L V8 Magnum RWD.
i am going to be installing a skyjack 2" poly value spacer lift with nitro shocks. than a 3" body lift (specific kit not picked out yet).
Currently i have the stock 16" rims and stock tire size on the truck. After I do the suspension and body lift i am interested in seeing if a set of 20" rims and 35" tires would fit with no rubbing.
Thoughts and ideas are greatly appreciated.
PIPTHEREDRAM
5.9 magnum
It will rub. I personally wouldn't put 35's on unless you do a lot of 4-wheeling, it's a 2wd! My gas milage went from 13mpg with stock 3.92 gearing to 7mpg. Not to mention the road noise and lack of handling. I think a leveled truck with 285)75/17's looks really sharp. You do you, don't worry about what other people think.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
The mods you want to make will allow you to effectively run a 285/16 tire. I don't know how that translates into a 20 inch rim but a 315/75/16 (which is about 35 inches), will not fit. You could probably stuff it in there, but turning and suspension travel would be very limited
Matt Bell
washington
I have 315/75/16 on my 01 2500, they will rub when the steering is cranked all the way over. V10 the mileage is always between 10-11.
