tire pressure
  1. Infotainment.com
    NOW AVAILABLE: 2019–2024 Ram 1500 & HD Factory Trailer Tire Pressure Monitoring System Upgrade
    Hey RAM Owners, If you tow with your Ram, you already know that constant thought in the back of your mind—are your trailer tires holding up back there? Without a proper monitoring system, you’re relying on guesswork or frequent stops just to be sure. That’s exactly why we’re excited to...
  2. R
    Steering rack harness
    The wires on the steering rack are loose (I think I broke the clip or where it latches on to). It will say it's ok but then after couple turns of the wheel the light will come on again. Also when I wiggle the wire around a little the tire pressure light will go on and off again.
  3. S
    3rd-Gen Tire Pressure & Loading Booklet
    Hello all! New owner of a 2008 Dodge Ram 1500 SLT Quad Cab 4x4 here. I'm in the midst of a minor tune-up, and discovered while setting my initial tire pressures that my Owner's Manual in the glove box is missing the "Tire Inflation Pressure & Loading" booklet that I've seen referenced elsewhere...
  4. Mike Shannon
    2020 Rebel recommended tire pressure for best ride?
    Looking for recommendations on the best tire pressure for my 2020 Rebel with Goodyear wrangler LT275 / 70R18
  5. Carlie
    Service Tire Pressure System
    Hi all, I keep getting this alert on my dash board. It shows the pressuren of my front 2 tires but won't give a reading for the rear tires. I do live in Maryland and it is pretty cold right ow, so I know the tire pressure readings will be off depending on the temp outside. But sometimes it...
  6. ebland0724
    Tire Pressure Indications Remote Start Issues
    Tire pressure indicators randomly go out for all four tires; sometimes at start-up but mostly random while driving. They will work fine for a week two then they all four go out for a weeek or so, then start working again. What is strange is that my remote start quits working the same time that...
