Service Tire Pressure System
Carlie
Maryland
Hi all,
I keep getting this alert on my dash board.
It shows the pressuren of my front 2 tires but won't give a reading for the rear tires.
I do live in Maryland and it is pretty cold right ow, so I know the tire pressure readings will be off depending on the temp outside.
But sometimes it comes on and sometimes it doesn't. Does this mean my tire sensors are going bad or is this a fuse thing.?
Any help would be appreciated.
OCDTech
Louisiana
Are they original, if so probably on their way out. Life expectancy 7-9 yrs average. Cold weather pulling the last juice out of the batteries in the sensors which are not replaceable (the batteries i mean). Probably need new sensors. Thing is they are all the same age i'm assuming, the others may soon follow. I had this happen on a Ford work truck. Do you know anyone with a tpms tool, they can run it around the 4 wheels and get a health report on each sensor if so.
We have weird weather here sometimes, i mean you can use the a/c and heater in the same day. So thats why my tps sensors wouldn't work in the morning, then they would in the day when all warmed up. Sign of very weak batteries.
R
Rampower2012
Guest
I see this all the time whith the TPMS sensors an yes that only have a max of 10 years if that you mite want to scane it whith a obd and that well tell you if that are bad I work at a tire shop so I see this all the time
RamCares
n/a
n/a
Hi all,
Hello Carlie,
Sorry to hear that you are experiencing this concern. With this in mind, I kindly suggest connecting with your local dealer if you are unable to remedy this concern with the assistance of fellow forum members. If you decide to go this route and you are in need of any assistance with that process, please feel free to send us a private message.
Laura
JeepCares
