water leak rear sliding window
  1. W
    Interior Roof Water Stains Around Speakers/Phone Mics
    Hi everyone, I just bought this used Ram 2019 Truck for $48K 5 months ago. It had 28K when I bought it. It now has 34K. Powered rear window. No sun roof. I don't have a garage so I park outside. I noticed about 1 month ago that there are water stains around the interior in the back roof at the...
  2. T
    Water leak at top of rear window
    I have a 2019 Ram 1500 Laramie 41926 miles with a leak just above the back window that is damaging the roof liner above the rear window on the drivers side. My dealership told me it is not covered by the Mopar extended warranty because they consider it a wear item. I don’t use the back window at...
  3. rix51
    How I fixed water leak on rear sliding window 09 Ram 1500
    Water would accumulate behind the rear seat and travel down the left rear and left front door sill which would then accumulate under the driver side floor matt. The cause was a rear window water drain hole that plugged up with dirt which caused the water to drip down inside the cab. To fix...
