I'm working on a 1994 Dodge Ram 2500 Light Duty Reg Cab 135" WB 4WD, it had a wobble at about 45mph, and while trying to sort it out I found the left front wheel bearing had quite a bit of play. I went looking for more info online but I wasn't able to find this particular configuration.
This hub...
My rear axle bearing blew up on my way home. Grooved my Axle rod and put a groove into the axle itself. Can I just smooth out the groove and install a new bearing or am I going to need a new axle?
I have a 2019 1500 bighorn 4wd and I need to replace the front wheel bearings. Anyone have recommendations on the brand and part numbers? I see several possible options on the mopar and Moog sites but I do not know the right one for my truck. Moog shows 2 types but their pilot knuckle diameter...
Hey all! My 2005 4x4 1500 dodge has started an inconsistent ticking upon acceleration. Sometimes it occurs when I turn corners, other times I could be driving in a straight line. In either situation, it's a hit or miss as to whether I will be able to hear it at all. At first, I believed that...
Hello everyone, this is my first thread on this site, although I have been lurking for awhile. Anyways, I have a 1998 Ram 1500 4x4 and am currently in the process of replacing the front wheel hub bearings (left one was shot, I decided to just replace both at the same time). I was able to change...
My wheel bearing fell apart the day after I took my front end apart, I had blown the front end and removed the guts including the axles. I re assembled the truck and the next day wheel bearing is gone, so I put a new bearing & hub assembly on and less than a km down the road same thing...
I was informed by a local Mechanic that my 06 Ram 1500 need s wheel bearings and I followed up with research and found that there is a recall to replace them. My question is will dodge do the repair being that is is #1 the recall is 12yrs old #2 the recall isn't list on the vehicle's vin.
Okay I got a slight front shake. All new ball joint are on the truck checked them no slop tie rods new within last year checked no side movement. Okay wheel bearings 3 years old on lift I don’t feel any movement but on the ground it feels as if the tire moves if ur push on the side of the tire...
