wheel bearings
  1. O
    Wheel Bearing
    Hello guys, I have an 2009 ram 1500 4x4 with the 5.7 hemi and I recently just got an alignment done and took it for a 2 hour round trip. Noticed I had a consistent steering wheel vibration and slight pull when I drove it over 70 mph. I was familiar with this vibration since I had to deal with it...
  2. 1ATony
    2012-2015 Ram 2500 TRQ front wheel bearing & hub assembly pair
    Shop now: 2012-2015 Ram 2500 TRQ front wheel bearing & hub assembly pair Limited Lifetime Warranty. Free same-day shipping. Part # 1ASHS01137
  3. 1ATony
    TRQ front wheel bearing & hub assembly pair for 2012-2015 Ram 2500
    This high quality, direct-fit, precision-engineered front wheel bearing & hub assembly pair is just what you need to get your Ram 2500 riding smoothly. Limited Lifetime Warranty. Free same-day shipping. Part # 1ASHS01137
  4. L
    2016 Ram 1500 “whistling” issue
    Hey guys, hope you can help me with an issue. I have a 2016 Ram 1500 5.7L, with a 4 inch lift on 35s. I am currently experiencing a “whistling” issue. I thought it may be a wheel bearing so I brought it to a shop and they could not figure it out either. It sounds like it is coming from the front...
  5. Ghostman
    Anyone have experience with "Synergy" HD steering kit and/or balljoints?
    Hello, I am needing to replace tie rod ends and balls joints, among many other things. I am looking for anyone who has experience and opinion on the Synergy products. I'm thinking of getting the Synergy HD steering/drag link kit, to replace the OE. I do have a 2008 Ram 2500 5.7L 4x4, it looks...
  6. D
    Whirring sound coming from front end...
    I own a 2013 Ram 1500 V8 4.7L Recently I had to replace CV and axle on Front L side. Technician at body shop told me that the differential fluid had been low after I got it changed at Grease Monkey ( ~ bad decision) and I also had them do an inspection and fluid exchange. I picked up the truck...
Carbary
