wheel spacers
  1. H
    Hub-centric Spacers on Stock Wheels for 37s
    Hey all, Has anyone run quality hub-centric spacers (ie: BORA, Spidertraxx) on the stock PW wheels to fit 37s? I know for aftermarket wheels +18 to +25 offset is ideal to fit 37s. If I went that route I'd likely going with AEVs, Methods, or Racline wheels with those specs. However, I...
  2. Boohoops
    What size wheel spacer?
    So I recently bought Toyo MTs 35x12.5R20 for my 2012 1500. It has the bilstein leveling set up on it. I also have aftermarket rims but I don’t know the actual offset as they came with the truck when I bought it. I now rub on the uca’s at almost full lock. Makes parking lot maneuvering a b*tch...
  3. Q
    Wheel Spacers with NO level/lift
    Hey Guys, 2020 1500 classic - 275/60/20 Duratracs on the stock black wheels. I’m looking to widen my stance out a bit with 1.5” spacers but I’m wondering if I will be able to clear without rubbing on the fenders. Anybody done this yet or is a level/lift necessary for any spacer use?
  4. Denis Ouellette
    Wheel spacers....
    I was wondering if anyone her has put 1.5" wheel spacers on a 2010 ram with stock suspension ....my wheel and tire set up is, 275/70/18 on 18x9 20mm ..... My question it if I put wheel spacers with no lift and this tire/ wheel combo will it rub? Sorry if this was converted before.....
Austinv
