Wheel spacers....
Denis Ouellette
Grand falls New Brunswick Canada
I was wondering if anyone her has put 1.5" wheel spacers on a 2010 ram with stock suspension ....my wheel and tire set up is,
275/70/18 on 18x9 20mm ..... My question it if I put wheel spacers with no lift and this tire/ wheel combo will it rub? Sorry if this was converted before.....
BOWERSFJ
Uniontown OH
Pull a wheel, and check to see what the min size is you can use, without having to trim your studs ... That way, if you need to go back, you can ... Bora is the first name in wheel spacers ... Their customer service can help you with anything you want to know
David Janes
Iowa
3.0 Diesel
You shouldn't rub. I put 2" spacers on with 20x9 and 33's and had minimal rubbing due to the ****** mudflaps I had
Austinv
