windshield wipers
  1. J
    Wipers don’t turn off
    So I’m at the point where I don’t know what to do next. The issue is that the wipers run on constant low, no matter what, when the fuse is installed. The only way the stop is to pull the wiper fuse. No other functions from the selector switch change anything. They even run on constant low when...
  2. D
    2008 Ram Windshield Wiper Problems
    2008 Ram 1500 4.7 I turned the wipers on and they were frozen to the windshield. I proceeded to free them. I turned the wipers back on. Now the wipers only work on high and it also doesn't go back to park position. The washers and everything else on multi-function control(turn signals, High...
  3. JeepManDan
    Windshield Sprayer Nozzle Gen 1 Dodge Ram Truck
    I broke off one of the original windshield sprayer nozzles on my 1989 Dodge Ram W-150 clearing snow too aggressively. Then I discovered nobody stocks them any more or sells a replacement. I designed, 3D printed at home, and tested my own part and it works great. I posted a listing in my Etsy...
  4. R
    New to Forums: Wiper Fluid Only Works with Turn Signal On
    Hey everyone. Just replaced both wiper fluid nozzles as they were both the original ones (they made it 150k miles) and were both broken. Driver side works find but the passenger side is still really weak. I suspect there is a clog somewhere along the line after the driver side nozzle but I'll...
  5. odins_rule
    Issues with intermittent wipers
    I've owned my 2012 6.7l Ram 2500 for close to 6 years now and ever since I bought it the wipers only work while washing the windshield and on the last two speed settings (fast and really fast). Although we don't get much rain here in California this is something that has always bothered me. It...
  6. Michigan BIGHORN
    Electrical confusion...
    2011 1500 4x4. Intermittent yet ongoing electrical "twitches". I've had the truck since June, approx 114,000 miles on it. I have this thing that happens especially if it sits for several days.....upon physically opening any of the doors the wipers will "twitch" and walk up the windshield about...
  7. Michigan BIGHORN
    Wiper/Horn/Entry lights acting up
    Longtime admirer, first time RAM owner.... Just bought a 2011 RAM 1500 Bighorn edition with 113,563 miles. Had the truck 3 whole days and ABSOLUTELY love everything about it. The truck appears to have been very well maintained and several VIN checks all confirm no major events and all recalls...
  8. R
    Fault Code U4121
    I can’t find what this fault code is but I think it’s linked to the following symptoms: When it starts and it's cold, the symptoms are: • Windshield wipers constantly running at normal speed: not adjustable or stoppable. • Steering wheel controls don't work. • Seat heaters don't work. •...
