wire harness
  1. ZeeGUY88
    2012 Big Horn converted to 2011 Laramie
    Hello to all. I am new to the forum but I am not new to turning wrenches. I was an automotive tech for about a decade before joining the Army as a 88L (watercraft engineer). As a happy byproduct of my service, I have been blessed with a very messed up spine. (Not looking for sympathy so please...
  2. T
    Passenger door speaker issue
    Recently purchased a 2002 Cummins. Passenger door speaker did not work. In the process of replacing it I found a crescent shaped thing plugged into the harness and speaker. Might be a dumb question but what is this. Is it an amplifier? Just trying to figure exactly what might be the issue if the...
  3. Joseanrdz20
    ETC flashing MAP sensor clip broken
    I recently replaced my spark plugs along with the MAP sensor I noticed the clip was broken there for I need a new harness? Or does anyone know a better way to fix the clip? I tried electrical tape for the mean time!
    I got left over wires I don’t know where they go …I color matched as much as I could and hit a wall left side seems to have more wires than the right
    PLEASE HELP!!!! My tire blew and ripped out my body/fram harness I’m trying to put humpty back together again but I ended up having 6 extra wires on the left side I don’t know where they go
  6. B
    2013 ram 2500 truck - 2018 truck bed - 2023 tailgate - 2023 bumper WIRING Issues
    Hello Everyone, Looking for any help I can find as you can see I jumped into something way over my head. 1st problem connecting my 2013 truck to the 2023 LED license plate lights 2nd the 2023 tailgate has the soft or electronic release button, came with no wiring attached to it. the releases...
  7. C
    2000 2500 NO BUS HELP GAUGES DEAD!!!
    Good morning! I'm having a hell of an issue with my truck. I've got a 2000 ram 2500 ext cab long bed with the 5.9 and auto trans. It's the Laramie model, but does not have every bell and whistle. I stopped at the package store over the weekend, shut the truck off, and when I came back out and...
  8. T
    Trailer Wiring Harness 2015 Ram 1500 Bighorn 3.6L
    Hi guys and gals , new member here . I have a question. I have a 2015 ram 1500 , Big horn quad cab , 3.6L. I recently noticed my trailer wiring plug was busted/corroded. So I Bought a plug and play from Hopkins. It was a 7 blade / flat 4 combo. When I crawled under the truck to remove the old...
  9. M
    Tapping into the Cargo light
    I ran new LED's under the bedrail, so that my bed is lit when the tonneau cover is on. The wire runs up under the cab, and into the truck through the wire harness by the battery. I'm trying to find out where the cargo light connects in. The cargo light itself is a white wire with a fat red...
  10. C
    Head light out again
    Howdy, So the headlight is out on my 2012 ram 1500 sport, the issue is I replaced the wire harness tail on both sides and now the driver's side is out again and I wanted to know why this is happening and how do I fix it. Please help.
Carbary
