0-60 times
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
I'll report back tommorrow, Wanna be at the shop by 09h00, got my tools ready and the plan which includes camera, laptop with Ol Dirty's DIY and the Ram shop manual just in case.
Later
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
****, that 87 tune blows, plus I had the wrong tire size in the adv tune. It had 31.5 I'm at 33. Turned a 8.61. 0-60. Pathetic, Gonna try next week again, I'll put in half a tank of 93. that should get me too 91 i'm sure. then I can 91 tune and try again with the updated tire size and 91 tune, we'll see what happens.
Rocket, make sure you actually measure your tires and don't just go by the size on the side of the tire. You need to have an accurate measurment or your speedo (and your datalogging times) will be all screwed up.
truckin151
2013 sport
Rocket... if you had a smaller tiresize programmed in, doesn't that mean that you were running faster than you would have with the larger? (or is that backwards)
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Cuz the tires are not stock, they are 33's. 265/60/20's. I measured them myself. I'm gonna double check, but I'm sure cuz I measured when I got her leveled.
S
Silverbullet08
Persona Non Grata
im sorry man but that is the stock size... :doh2:
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Well they are thirty three inches in diameter, Well, not exactly. I admit there a smidgen off. But certainly not, 31.5."s They 32and 7/8th's too be exact.Thats stock, 31.5???? How the **** does that happen?? lol
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Yep, if you adjust to a smalleller tire size than what the actual tire size is than the speedo and data logging will show faster times. Correct tire size is critical to accurate data logging and speedo readings.
truckin151
2013 sport
Thats what I had thought VA, so really if his 0-60 was 8.61 with the smaller tire size, if alll conditions are the same except for changing to the correct larger diameter tire size, his times are going to get slower. Sorry Rocket
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Wow I blame the tune then, cuz i haven't had a vehicle this quick since, my state police interceptor, calm down boys it was a 72 ford custom sedan. But it came with a 429 factory headers, dual exhaust. And certified calibrated speedo. Registering 140 mph. Why else would I be so slow? anybody fathom a guess.? Could my hemi be a pig? naw I doubt it ,it's the 87 tune.
here are my settings , are they too soft in anybodies opinion?
Uh rev limiter 5900'
1-2 wot 5700
3-4 wot 5650
No tranny tune yet.
burning 89 octane. filled up before the sc was directed my way.
So mileage xs for now. pretty lame I mean tame. Compared too the likes in this thread.
But the speedo was set at 31.5 is that not smaller than what I have? I tuned too thirty three and did a 60 mh time est. I was right on. A mile a minute. So I should be a tad faster next time out.My head hurts, thinking too much lol. need a beer.
Also just thinking the stock tire size for a 17 inch wheel would be 31.5 would it not. It doesn't change the fact that I need the better gas too really get the best out of my tune. Oh and by the way I'm not doing a tranny shift yet either.This should be posted above but while I have your attention does a pcm Clear , change a tune back too stock??
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Rocket my first good Log was 8.39 so don't be disapointed. May I suggest shifting manually with OD off.
Hammer her from L1 and when you get to 5800 on the tach shift the lever up into 2, then your done (sort of) she'll rev up again but by then you'll hit 60 MPH before you would have to shift again to D, so when you surpass 60 shift into drive then back off the throttle (like when you drove the Ford and didn't want to slacken the Timing Chain).
Betcha You'll dial in somewhere in the sevens.
I,ll tell you about my datalog experience tommorrow after my TC install which went well BTW, but I got tire spin now so gotta figure a way around that (I.E. more Mods..WTF...LOL..) Nite.Nite..
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Sounds like you are pretty well prepared then. Good luck and may the gods of truck be with you.
Thanks for the Good Luck Call Man. The Gods where good to me even with a 3 hour delay to starting, was done in 6 hours (transfer case to deal with too!)
truckin151
2013 sport
No, you should be a tad SLOWER the next time out assuming that all the factors are the same from the run you did last time. The smaller tire diameter actually made your times faster than they would have been if they were set correctly.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds about right on that shift pattern with stock internals, next in line is get your a cam and bump it up to 6k.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
This is what I did with no o/d and the mileage xs tune, adv tune with previously posted rev limits, and a 32.50 tire, Smaller than what i Measured btw. But this time I loaded up on the throttle before takeoff, and shifted manually. I can live with this btw.
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Much more acceptable !
When running WOT runs how much of a difference does it make to turn OD off and shift 1-2 manually ? I'm going to assume you let off the gas a smiggin when doing the shift . . . or will the stock TM handle the shift with the peddle still depressed ?
If I get interesting answers I may try to one up my previous 7.21 :drool:
rocket
Pennsylvania
was 2006
was a HEMI 5.7
I had no problems. Foot to the floor!! I was able too knock off A full second with the larger tire, And was supposed to go slower. Had I not changed the tune too mileage xs. better kick than the 87 tune btw.
