0 Gauge
pd298
SE Oklahoma
Has anyone ran 0 Gauge power wire in their truck?
If you have, post up some pictures of your wiring route, and explain how you ran through the firewall, and how you hid the wire in your truck.
Feel free to post up pics of other amp installations too.
Rumblebee#2331
Vernon,Ct
I used 4, I want through the rubber grommet hole in the fire wall for the e brake, just pushed it to the side and ran the power under the door sill and under the carpet to under the seat where its already cut for the power seat wiring, I ran the ground to a factory ground just to the inside of the drivers door, amp just sits under my drivers seat, and I ran speaker wire under the rear door sill to under the back seat.
S
scotts2012ram
Guest
I ran mine thought the clutch delete plate then ran it the same way rumble bee did
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
just for your 1500.1?
pd298
pd298
SE Oklahoma
Yep. That's what the guys on the audio forums recommended.
pd298
pd298
SE Oklahoma
And the terminals on the amp are 0 gauge, so I figured that's what kicker wants you to use.
Graygoose
Oklahoma
Convert, for now.
small
Yes, 0 gauge would be more than fine, better to have more than less. And yes, we recommend 0 gauge :)
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
I ran my 0 wire along the frame under the drivers side and put a hole under the back seats. Pic in my build thread somewhere.
Graygoose
Oklahoma
Convert, for now.
small
I guess you work for kicker.. what do you do?
yes
Recommend, but is it really needed???
when it comes to current, can you over kill?
having an amp run with less volatge is less pwoer, and DC, or clipped signal. You can never have too much, plus, some want up too' a 0 gauge input.
Voodoochi1d
Temple, Ga
I ran 0 gauge into truck cab thru clutch delete, and then 4 gauge from power dist block to each of my 2 amps, Im about to pull 1 of my 4 gauge runs however and replace with 0/1 gauge. Need more POWAHHH!!!! lol
pd298
pd298
SE Oklahoma
What is this clutch delete that people keep bringing up, a preexisting hole?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
its a plate in the firewall. Its plastic, so its nice and easy to drill through.
pd298
pd298
SE Oklahoma
Can someone post a pic of where its at?
Voodoochi1d
Temple, Ga
pd298
pd298
SE Oklahoma
Is that last pic after you drilled a hole or is it preexisting?
S
scotts2012ram
Guest
The hole in the metal is already there. Its just a plastic cover that's bolted over it
pd298
pd298
SE Oklahoma
So you dont have to do any drilling to run the wire through the firewall at all? Or did you remove the plastic cover in order to run the wire through?
S
scotts2012ram
Guest
Remove the plate drill your hole in the plate. Then bolt the plate back in and then run your wire
