01 RAM Stalling issues
pamante
Help - I have a 2001 Dodge RAM 1500 4x4 Extended Cab I bought new in 01. It now has 188k miles on it. It stalls intermittently. Sometimes it starts right back up. Sometimes you have to wait 5-10 minutes. I have replaced
TPS x 2 - second time with connector
Crak position Sensor
IAC
Ignition circuit breaker in the under hood distribution box
Distributor pick up
Distributor Cap
Rotor
Coil
Ignition switch
It is not losing oil so I don't think it is the plenum. Runs fine when it is running. Battery seems good - cranks fast. No codes - there was a high voltage code from the TPS so I replaced it a second time.
Wife has had - she won't even get it in now. Any suggestions would be appreciated
Paul
bhonshell37
Washington
Have you checked the oil pressure sending switch. It sits behind the throttle body and requires a specific socket to remove. My friend has a starting issue and that was the culprit.
Sent from my SM-T550 using Tapatalk
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
Trade it in and get a new one :)
Sent from my SM-G935V using Tapatalk
capebreton1967
