02 Ram 1500 5.9
DahRamGuy
Mebane, NC, USA
Truck randomly stalls on me, when it does the gauges on the dash don't work but everything else does. After a while of letting the key sit in the on position the gauges will come back, and the truck will start. I've change the position sensor, spark plugs, pcm/ecu, Tipm module, and the ignition coil. Anyone who had this issue and fix it please help.
1999 White C5 Coupe
I haven’t had this issue in a Ram.
I did have a 2003 Dodge Durango SLT 4WD with the 5.9, purchased new, that would randomly stall and not restart. I had it towed to the dealer and they diagnosed a bad cell in the battery (which was not very old).
You did not mention the battery and/or the cables and connectors. Are you SURE they are all okay, clean and tight?
