Milkman44107
- Aug 17, 2012
- 11
- 0
- 2002
- 4.7L V8
Hi Guys!
I recently purchased a 02 Ram 1500 Quad Cab with 4.7L V8 engine. I got the truck for a really good deal. So of course it will have a few issues.
One is my Driver side door seems to be off alignment a little (hangs a tad low), blown driver door speaker, support handle on driver side leaks water from bolt hole and finally.. the part I want to start with, lol. The rear driver side door lock actuator.
When I hit the lock button all the doors lock fine. However, when I hit the unlock button. That rear driver side door lock struggles to pop up. If I keep hitting the unlock button it slowly inches up. I usually have to end up manually pulling it up. The odd thing is the lock is easy going down and so stiff pulling up..
I have tried to work the lock to see if I can loosen it up. However, no luck what so ever. I don't think it is suffering from the loose wire scenario. This seems more of like too much resistance in the free play movement.
If the lock actuator has to be replaced is it a easy job and also does anyone know where I could get one quick and cheap?
Thanks for the help guys!
