04 5.7 stall out..
04Hemi69
Ok guys and gals.. New to this here. Got a 04 5.7. Headin' down the road just after dark. Truck running about 60mph. No warning all of a sudden truck shut down. Coasted to a parking lot and has not started since. Fuel issue? Throttle body cleaned. New Egr valve. Tube cleaned to the Egr. Checked all sorts of connections. Anybody have ideas for me?
Sparkyy
Northern New Jersey
v6
Is the battery still original? Has it been checked to see if it even has a charge? How about the alternator, cause if that is bad, it doesn't matter on the battery at that point.
Can you try to crank it over or is there just no noise at all?
NYCruiser
Yonkers, NY
Not enough info. Is it cranking, as Sparkyy asked. If it is, is it getting spark? You're going to have to check some stuff to determine if it is electrical or fuel related. No CEL light on prior?
04Hemi69
Engine cranks over great. New alternator two months ago. Not sure if it's getting spark. Haven't checked for that. So new alternator ..new battery.. New EGR.
04Hemi69
Also had no lights...no warning.. Nothin...just stopped
NYCruiser
Yonkers, NY
Easy enough to check for spark. If its got spark, that eliminates a lot of stuff. Then start looking at fuel.
04Hemi69
Ok guys..fuel pump! A little set back.. be back in her in 2 days. Thanks guys! Soon upload pictures of what she looks like after a few add- ons. Once I figure this out..
