05 Dodge Ram 1500 5.7L Wondering Where Too Start?
Dabneyskeys
U.S.A
5.7L V8
Fixing up my ram that's been sitting, starts, runs and drives great but I have not been driving it because of the Engine Trouble codes it has and I am just getting time to look at it.
I am currently getting codes,
- P0174 - system to lean bank 2
- P0151 - 02 sensor circuit low voltage bank 2 sensor 1
- P0404 - Exhaust Gas Recirculation control circuit range/performance
- P0700 - Transmission Control System (MIL Request)
Before it set i was only getting the P0174 code.
I had the cat's replaced previously and I replaced up and down stream 02 sensors when I got the 02 code but the code came back.
I was looking for advice on where to start
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Check the wiring to the cats. Make sure the wires are not broken or melted. Sometimes the wiring can get melted on the exhaust.
D
Dabneyskeys
U.S.A
5.7L V8
The wiring from all 4, 02 sensors look new still. And I don’t see any damage from the plug to the harness either.
Also I inspected the exhaust and there are no contact points with any wiring, everything is tucked out of the way.
Brando_SLT
North Country, NH
To me this looks like a bad EGR valve/gaskets and bad oxygen sensors. I'd replace them all, if the wiring and connectors all look good.
Daw14
South Florida
Did you use mopar 02 sensors ? Aftermarket doesn’t always play well with our trucks .
