dodge ram 1500
  1. B
    2025 Ram 1500 Bighorn SST V6 w Turbo
    I have 600 miles on this new truck and have 4 issues already. 1. Dashboard went completely dark while driving. Stopped the truck. Turned off the engine and turn it back on, still no dashboard, no blinker indicator, nothing. Truck would not go into gear. Turned engine off again, then it went into...
  2. Off-Road Control
    Dodge RAM 1500 5.7 Hemi vs 3.0 TDI [Mud Off-Road]
    Car Features: - Dodge Ram 5.7 hemi 1500 (black): 5.7 HEMI (lift 3.5") 35" Farroad Mud Hunter - Dodge Ram (white): 3.0 TDI (lift 4") https://youtu.be/_NngekZXAC8
  3. A
    4WD works inconsistently?
    I drive a 2007 Dodge Ram 1500 Quad Cab Big Horn Edition with a 5.7L hemi and almost 260,000 miles on it. It has an Electronic Shift On-the-Fly (ESOF) 4-wheel drive transfer case that allows me to choose between four different drive settings by turning a dash-mounted selector dial; the settings...
  4. R
    Low Power Up Hill Still after plenum replace and cat inspection
    2001 Dodge Ram 1500, 5.2L with 46re trans 96k miles After reading a copious amount of posts on here over the past few years and learning a lot, thanks to all of you! Need your help once more, still low power up hill. It seemed to have gotten a bit better after plenum change along with a few...
  5. P
    Can we change fuse positions in the fuse box for an accessory? - USB is always on.
    2022 Dodge RAM 1500 Classic SLT Center console has 2 USB ports that are always on. (I read somewhere that they shut off after an hour or two, but mine don't. Had a USB accessory plugged in for 2 days without driving and killed the battery). Can I jump it's fuse location to another circuit...
  6. Jessg13
    2003 dodge ram 1500 tires
    My dad passed away a couple years ago & left me his beloved '03 1500. It's a manual 4x4 and I love it. I've been trying to teach myself how to fix a few things. Figured out & changed the spark plugs by myself (which if you knew what a ****** I am, you'd be super impressed). Recently I've had...
  7. 9
    Truck Running rough
    Hi all, I’ve got a 99 ram 1500 5 speed 4wd that is running like crap. Idles rough, and will barely pull itself out of the drive way. The engine has new: cap,rotor,plugs, wires, coil, o2 sensors,injectors, cam sensor and crank sensor. I’ve tested and tried everything I know to test and replace...
  8. Off-Road Control
    Dodge RAM 1500 5.7 Hemi vs UAZ [MUD OFF Road]
    https://youtu.be/UhIDNHfAZ4s Dodge RAM 1500 5.7 Hemi vs UAZ [MUD OFF Road] Hello, went off-road with friends in search of adventure. Many interesting cars took part in this event. Standard unprepared Dodge Ram 1500 5.7 Hemi Big Horn, two UAZ with large 36 inch tractor wheels with axles from...
  9. D
    05 Dodge Ram 1500 5.7L Wondering Where Too Start?
    Fixing up my ram that's been sitting, starts, runs and drives great but I have not been driving it because of the Engine Trouble codes it has and I am just getting time to look at it. I am currently getting codes, - P0174 - system to lean bank 2 - P0151 - 02 sensor circuit low voltage bank 2...
  10. RamTough7862
    OBDll SCANNER/DIAGNOSTIC/RESET TOOL
    IF YOU OWN A VEHICLE WITH A COMPUTER IN IT AND DO MOST OF THE WORK ON YOUR VEHICLE YOURSELF. RESEARCH WHICH "OBDll" SCANNER BEST FITS YOUR NEEDS TO SCAN, DIAGNOSE & RESET KEY COMPONENTS ON YOUR HOT ROD. >>> IF YOU JUMP ANOTHER VEHICLE VIA JUMPER CABLES, YOU CAN SCREW UP YOUR COMPONENTS IF...
  11. Off-Road Control
    DODGE RAM 1500 vs UAZ vs ZAZ Monster. Stuck ALL [MUD OFF Road]
    Vehicle characteristics: - Dodge Ram 1500 Big Horn: 5.7 HEMI automatic transmission 34.4” BFGoodrich All Terrain - UAZ 469: 2.5 Mechanical transmission 36” Tractor wheels FBel-160 - ZAZ 968M Monster / Zaporozhets: 2.5 ZMZ-405 manual transmission Axles / Suspension from UAZ 33" Forward Safari...
  12. S
    Building transmission
    I want to build my transmission to hold up to at least 800 hp. What rebuild kits and torque converters are y’all running
  13. Ravi Dass
    Sway Bars rusted off
    Hey All, I was informed (by Dodge) that my sway bar links have rusted off therefore they are not covered by MOPAR lifetime warranty. Any recommendations for sway bars for a 2013 RAM 1500 Sport. Has about 245k miles so Im thinking I just replace the front and rear. Anything else that should be...
  14. TexasWhiteBoy
    Do you recognize this Grille Guard?
    Found this nice brush guard in a barn but it has no brand or part number visible, has no brackets either! Would like to order the correct brackets for 2011 Ram 1500. Please help!
  15. J
    LED Lights Acting Up
    I have a 2002 Ram 1500 and I decided to do some lighting upgrades and throw in some LEDs. There is just one thing that bothers me though. After the truck has been sitting for a little bit, I open the door and every led light on it blinks, even if they have a load resistor on them. Was just...
  16. D
    Name of part help
    Is there anyone that knows the actual name of this part that goes on the backside of the window? The hard plastic piece, everything I find is referred to the C pillar but I can't find the part anywhere.
  17. Donyell
    Hmm
    Should I put a flow master super 10 and axle dump with a 5inch outlet tip
  18. Lifted_ram_18
    Blown diff
    Good morning all, so yesterday im driving along, feel a loud pop, then my truck is in like neutral, look under thinking i snapped the drive shaft but its still spinning, so i put it in 4wd lock, to get me off the road, starts going then goes back as in neutral, saying 4wd power reduce due to...
  19. C
    Front differential
    I have a 2003 Dodge Ram 1500 4x4 and my front axles have a lot of play moving but it’s the stub shaft bearings and seal that went out, and I was wondering what bearings and seal to order and how do I go about changing them
  20. S
    Front Drive Shaft CV Joint Rebuild/prop shaft cv
    Aloha from Hawaii I have a 2004 Dodge Ram 1500 5.7 liter Hemi 4x4 and the boot on the Front drive shaft/prop shaft cv joint disintegrated and I am trying to replace it. I ordered the parts/kit from 1A Auto and have removed the front of the old cv joint but don't know how to remove the rest of...
