BigRig84
My dad’s 06’ 5.7 wont turn over.
We hear the click at the solenoid.
Battery is good
We jumped across the solenoid and it cranks but won’t start. Made sure the key was on
Fuel pump is kicking on, plus it was replaced a few months ago
Tried to clean the terminals on starter and broke the connector stud, so just put a new starter on and it’s doing the same thing
Ignition relay is good
All fuses that we know of are good
Thought it could be neutral safety switch, but backup lights work when we shift it in reverse
Tried to start in park and neutral and wiggled the shifter a bit
Thought maybe an anti theft device, but can’t find anything to check.
Would a crank position sensor keep it from cranking? I know they will keep it from sparking, but not sure about cranking.
Any help will be greatly appreciated! I feel bad for my dad. I gave him this one when I upgraded last year and he’s had nothing but problems with it.
A friend suggested this forum so hopefully one of you guys have an idea. Thanks!
Battery is good
