06-08 dash trim
leonard12
Philipsburg, PA
I have an 06 slt with the wood grain on the bezel and on the door panels and personally I think its ugly. I wanted to paint it but then realized that the wood grain and the bezel are all one piece. So my question is do they make kits that you can put like an overlay or something over the wood grain. Or I even thought about putting window tint over it and trying to make it look like black wood grain.
OD Ram
Tampa FL
Magnum 4.7
Plasti-dip or rustoleum paint all look good in the end. Personally I'd go for the paint. Sand it down and paint it right. Plasti-dip isn't going to be great in all the heat.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
Vinyl wrap would be another option for you. A lot of folks use it on hoods, and it will handle the heat, as well as rubbing. There some very cool designs such as Carbon Fiber.
But I would definitely also consider painting. When painting plastic parts I use an adhesion promoter and it really helps.
MADDOG
Living in a Firepit
6.4L HEMI
I'd recommend a vinyl wrap.
BgHrn
IL
I've got the same wood grain, trim. Yuck. How do you remove those pieces?
BgHrn
IL
TTT, anybody have advice as to how to get the wood grain trim off? Id rather not break the trim panel, trying to get it off the vehicle.
usaf2006
North Carolina
I read a diy somewhere... possibly this forum. If I remember correctly it was a pain...
Ethan0524
Earth
I just took the whole piece off the dash board, taped it, then sprayed a few coats of plasti-dip...
picture.php
You could do the same with the doors, just a few screws and a little bit of pulling and you can take it out, tape it, and spray it as well.
BgHrn
IL
Sweet, thats a good idea. Cheap fix as well.
BgHrn
IL
Does anybody know where or have seen, those "dash kits" for our trucks? It covers the radio bezel and each piece on the L/H and R/H door panel?
jei3us
5.7l hemi
Plasti dip might be good for the dash bezel as long as it's not touched but I'd rather have permanent results. Plasti dip will fade over time requires touching up or re doing. I plasti dipped my control panel it didn't last a month before it started rubbing off from normal wear. Ended up sanding down priming and spray painting them satin black. With a clear coat it came out awesome and it lasts.
joshhhh
