06 2wd level kit?
sportstud0903
Saginaw, TX
Magnum 4.7
I have an 06 2WD 1500, the back measures 41" off the ground while the front only measures 38" When i was looking at leveling it online; 4 wheel parts only has a 2 inch lift. I have found a 3 inch billet aluminum spacer kit. Will that do the trick? What is the best thing to get or do?
S
sportstud0903
Saginaw, TX
Magnum 4.7
yeah im trying to stay kinda cheap for the level because im saving for my lift and i can get the 3" front level for $125
TexasAggie18
My 2002 differs about 3 inches too, im at 38 in the back and 35 in the front. What type of level are you using, where did you find it?
matt99
Shreveport, LA
there is a thread literally two before this with info on this. Look at it. And you will not put a 3in $125 level on there and not end up with problems
